RTD question
Howdy CW: question for you, where in the tank is the tech placing his temp detector?
I had a similar problem years ago, (with acid & caustic tanks) the rtd's were mounted on the right hand side of the tank, about 6 inches below liquid level. in my case the qa tech would come by and stick his temp probe in any part of the tank but not near the rtd. he was alwayz complaining that the temps are off, we did some checking and found out that our chem mix, was odd, the heaters were at the bottom, and for some reason the heat didn't rise evenly like it wwould in a tank of water. we used a 3' probe and found different temps at different levels in the acid. we eventually found a solution, we put some small pumps on the side of the tank that would intake the top level of acid, and discharge it from the bottom of the tanks via a type of spray nozzle, this kept the temp stable and the chemicals mixed.
Good point Tracer.
I would still substitute a resistor to simulate the temperature to see if it drifts that way.
Look for moisture inside the head and any associated terminal boxes also.
Roy
I have a 1000 ohm 3 wire rtd going to a a.b. Rtd module using slc5oo software i'm thinking a scp is best to scale it and then display on a...
1,629
Good day all. I would like to know if anyone might know why the Control Logix RTD modules do not require a drain wire (shield) connected to it...
3,425
Good day all, I changed the configuration of an RTD Module and when I resumed the program the system had a fault and shut-down. The module is a...
4,778
Good day all. I have an RTD module for a SLC500 5/03 that I can't get the temperature values to stop jumping from one temp to the next, on the HMI...
4,675
Hello all. I have two RTD's in the same acid tank. One reads 104 degrees F and the second is reading 54 degrees F. They are both at the same level...
1,943
