RTD signal to a PC
Martindag
Sep 2009
quebec
227
Hi guys,
im looking for a way to monitor 20 RTD probe into 2-3 PC. I hear that there is a way to convert RTD into Ethernet IP and read them with a software but thats all.
Do you guys know any good product for this application ?.
Im looking for low price of course.. like always :D
also maybe a option to add thermocouple if needed.
Atleast 20 RTD input or more.
and i need to install that monitoring software or whatever on 3 PC atleast. or if it's a .exe share it into our network and make shortcut or something to the PC connected to it.
Waiting for your feedback, thank you !
Martin
We have remote data acquisition modules which communicate via Modbus TCP. Using
our ET-7015 which has 7 RTD inputs per module (you will need 3 for 20 probes).
http://www.icpdas-usa.com/et_7015.html
On each PC, you can either log into the web interface to view the temperature status using Internet Explorer or you can use our Free EZ Datalogger software(Free for up to 64 IO tags) to either data log or view the status from a user interface of your design.
http://www.icpdas-usa.com/advanced_ez_data_logger.html
A bit off topic, but I have an old heat trace controller where they used the power cable to get the rtd reading. They have lil pc board at the rtd...
2,013
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,202
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,647
We are running a power flex 70 connected to a Delta V and I cannot get the drive to start because I am getting a STOP ASSERTD message on my HMI. I...
3,054
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,064
