Running PLC Programm
RockyWells
Mar 2020
Edmonton
Hi All, I am writing a piece of software for some research and would like to retrieve a running program from a PLC using python or some other available API.
I would be testing this on a MicroLogix AllenBradley shoebox PLC
Does anyone know what API or Library calls I could use to achieve this?
Is this in one of the Protocols like Modbus?
Thx!
Thanks Steve, I believe modbus may support this, the protocol suggests there is a read and write file operation.
The program file is supposed to be file 2 . I need to confirm this.
I want to be able to draw my own image from the ladder logic in the file.
You can buy a copy of RSLOGIX500 from your local Rexell dealer for around 150.00 dollars. I have never heard of using the comm protocol ModBus for a MicroLogix program download. But alas...I am mildly retarded at times. There are free options for students I believe. Hope this helps.
Yes I have a copy, I am looking to connect some advanced technology I am working on *** TOP SECRET *** to download running programs from PLC via API or some lib.
It is for some cloud analytics,so I want to have my own driver stack, it will all be driven from backend servers.
No Upload, just download as step 1.
In this context, a "file" is not something stored in a conventional filesystem. It's a section of application code memory. "Modbus files" are literally little 16-bit data memory registers used to exchange small amounts of data between controllers and supervisory systems.
In general, the functions used to upload (from the PLC to a PC/Server) or download (the other direction) are not documented, nor an API well supported, for use by third-party software. It's largely proprietary.
Doesn't mean you can't figure it out. And just because I can't think of a "cloud analytics" reason to read the application code of a MicroLogix doesn't mean there isn't one.
There is already a disaster recovery / automated archive / upload-and-compare product on the market, called FactoryTalk AssetCentre.
Thank-you for all the options, the source forge lib is probably the best place to look into. I was hoping there were some more public APIs for this or standard protocols I could implement.
Time to dig out the old protocol analyzers! :geek:
To the stuxnet guy, pssst buy more gold. :sleep:
How to fix if appears code “$115 plc-restart running” on the screen OP17
248
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
96
Hello everybody, I am working on a project which has HMI FTView SE 13 (Local) and controllogix L71 PLC. I have a question how does PLC detect a...
514
Just had the anomaly. Stamping press, 20 years old, SLC5/04 CPU with EEPROM memory module. The customer says suddenly a couple days ago they...
25
9,554
Good Morning , I should know this . I would like to import some rungs into a running ControlLogix PLC . Can you actually keep a...
1,623
