Running PLC Programm
No Upload, just download as step 1.
FYI, for every PLC I've ever used, "Upload" means from PLC to PC, and "Download" means from PC to PLC. Might vary brand by brand, though.
FYI as well that Siemens does offer an API called Openness which allows you to make programmatic calls for 95% of the things you can do in the Engineering environment, including uploading the project. I think you would need to export it after that, if you wanted to access something like the PLC code from an external program.
Siemens software won't help you much for an AB PLC though.
I was wondering if you could point me in the right direction. I am trying to write a string to an array Tag but I want to write to the next empty tag. Not sure how to do this since I am new to python. Any help would be appreciated.
Ex: ID_Data_Table_Name
Data type: string, 200
So you have a a STRING array that is a length of 200, you need to write to all 200 STRING's? Or is your tag a custom STRING that is 200 characters long?
Edit. You should probably start a new thread rather for this. Give the details I asked for in the new thread and I'll help you out.
How to fix if appears code “$115 plc-restart running” on the screen OP17
249
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
97
Hello everybody, I am working on a project which has HMI FTView SE 13 (Local) and controllogix L71 PLC. I have a question how does PLC detect a...
514
Just had the anomaly. Stamping press, 20 years old, SLC5/04 CPU with EEPROM memory module. The customer says suddenly a couple days ago they...
25
9,557
Good Morning , I should know this . I would like to import some rungs into a running ControlLogix PLC . Can you actually keep a...
1,624
