Running Virtual Machine
Oct 2015
Beaumont
28
I have two laptops that I use for RSLOGIX. One is an older Dell with windows 7 pro, and the newer Dell has windows 10. Everything works great on the windows 7 pro. I can run Rslogix 5000 on the windows 10, but not Rs networx or factory talk studio. I use the older laptop for the field and the new one is for personal/ business. The newer one has the license file, I networked them together so that they can share the license file. I Was thinking about installing vmware on the newer one with windows 7 pro. Any thoughts or suggestions?
Thomas
Hey Thomas, I think you'll find that many, many people run their automation software in a VM exactly like you are suggesting.
Correct, each VMware virtual machine needs it own Windows license. If you work for a larger company you might have your own Windows Activation Server which means you don't have to purchase anything yourself, the company would have a pool of licenses you could draw from. If not, then, you would need to buy a standalone license.
OG
I run a vmware copy of windows 7 pro for all my AB software, on a windows 7 ultimate laptop. Once you have setup your VM correctly where it has access to all the correct ports, I found it works pretty flawlessly.
Windows 10 is obviously newer, and I've yet to hear very much talk about people using it for automation software. I am interested to see how it goes for you.
Any advice on below issue? ➢ IFix 5.0 with USB Hardware Dongle License Standalone application connected to RX3i PLC units via Ethernet (bridged...
1,630
I'm sure there are some protections on this, but I want to start moving some projects to Advanced HMI (not sure of all the limitations). I'm...
2,218
I'm having to do work using multiple versions of RSLogix 5000. The project I have coming up needs version 13.04 which I've found won't run at all...
4,957
In future I should like to use a virtual pc to run my programming software. My preference goes to a free release of VMWare virtual pc. I have now...
5,828
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
149
