Rx3i Dual Bus PLC swapping issue
adnan_hayat88
Apr 2013
Karachi
46
I have a Rx3i Redundant Controller with Dual Bus configuration connected to a Remote NIU(IC200GBI001). I am having an issue that if I swap the PLC from Primary to Secondary controller or vice versa the Remote I/O go to their initial state and then update. What is the Problem. My NIU card is also showing 'Fault' light ON.
Maybe the problem is the "Fault". Fix whatever is causing that and see if your problem goes away.
Can anyone tell me whether Rx3i GBC controller IC694BEM331 works in dual bus configuration.
1,805
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
393
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
287
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
108
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
980
