S5 135U communication problem
srik
Sep 2005
hyderabad
104
Dear Sirs,
We are using S5 135U with CPU 928 and TTY converter for programmer communication purpose. This TTY converter is working with PLC com port internal supply. Now the communication problem is raised. I checked this TTY converter with another PLC. It is working. Now I confirmed that TTY converter is not working. This TTY converter was newly purchased. Old one is worked with external supply. It is worked for almost 10 years.
Now I need following clarifications:
1. Can siemens repair this COM port?
2. can I use the TTY converter with external supply?( The TTY converter has a provision to give external supply)
3. Can I use any interface module for communication purpose?( We are using CP143 with since H1 for MMI communication)
please read the question as below. earlier one has some mistakes
srik said:
Dear Sirs,
We are using S5 135U with CPU 928 and TTY converter for programmer communication purpose. This TTY converter is working with PLC com port internal supply. Now the communication problem is raised. I checked this TTY converter with another PLC. It is working. Now I confirmed that COM port is not working. This TTY converter was newly purchased. Old one is worked with external supply. It is worked for almost 10 years.
2. can I use the TTY converter with external supply?( The TTY converter has a provision to give external supply. Iam expecting the supply system in COM port only damaged)
problem in a communication that lost bet. S5 135U (ALARM S3964RDDE SERVER) & In Touch Hi all experts and members ...
2,126
Dear All, Here s5 & S7 both the programs are attached.Communication between S5 and S7 is working very nicely with these programs, my problem is...
4,198
We are using S5 135U with CPU 928 and TTY converter for programmer communication purpose. This TTY converter is working with PLC com port internal...
5,679
i am using cp 525 for communication between fix 7.0 (fix 32) and 135 u.I am able to communicate.I am able to write data instantaniously but reding...
2,674
Good morning Please i need an advise, I have a s5 135u cpu system , it is installed on printing machine. Nowadays its stop about 10 times in 8...
27
4,266
