S5-135U program transfer problem
viikku
Jan 2010
H
I tried to backup program from PLC but all I got was couple of DB's and DX's. I used STEP5 and S5 for Windows, both showed the same blocks. Was I seeing only the memory card and how I get all blocks transferred to PC.
I had "B" in Block list of Transfer block(s) window. I tried also to browse the blocks by double clicking Block list and it showed me only a few blocks, DB's and DX's. Then I tried a back up from S5-100U, in same way with same "B" selector in Block list. It worked ok.
I also tried "S5 for windows" for this problematic CPU. It showed also only DB's and DX's.
Is it possible that CPU should be in STOP-mode when backing up?
The production line was currently at stand still and without operating current so it had none of the outputs on. I asked when was the line running last and it was hour ago, so I assumed there has to be working program in the memory.
The PLC card has a RAM card installed, no EEPROM, so I checked the system manual of s5-135u and if I understand correctly DB's and DX's locate on RAM. Only idea I have is that STEP5 showed me the blocks from RAM card.
What is the MLFB number of the CPU?
It could be that the program is hidden in some way. The DB's or DX's might be renamed OB's.
Could you post a print of the DB/DX'es?
Perhaps upload a zip of the s5d-code as well?
Kalle
I tried to download the program to the S5 135U CPU 928B we have in our office for testing but was not able to do so. When I try to delete the...
4,107
after transfer program from PG to PLC (CPU 135 U STEP 5 ) STOP LED IS flashes try to do manual cold restart stop led still flashes please...
2,981
Good morning Please i need an advise, I have a s5 135u cpu system , it is installed on printing machine. Nowadays its stop about 10 times in 8...
27
4,267
I have an S5-135U. We had a problem in the past where if we unplugged our Siemens M4 PG while still in Windows but offline and out of STEP5. The...
2,968
I have an Siemens S5 135 system. The CPU 6ES5 928-3UB12 Will not go into run mode even after a MASTER RESET or AN OVERALL RESET using a...
2,873
