S5, 6ES5 928-3UA12 and 6ES5 928-3UB21
Alpha
May 2003
35
Our S5 135U PLC system use CPU928B(6ES5 928-3UA12,double slots wide), but the new sparpart is 6ES5 928-3UB21 (single slot wide). Can I substitute it dirictly? Which slot I have to plug it in? Do we need COM DB1 to reparameter? Thanks!
The following is from the Siemens Web Site.....
The CPUs 928A/B have been redesigned and now require only one slot space.
A RAM with maximum capacity has been integrated in the module.
Memory cards with Flash EPROMs are used instead of the previous EPROM or RAM submodules.
The new CPUs 928 are functionally fully compatible with the existing modules.
The technical specifications and the runtimes of the new modules are nearly identical to those of the existing CPUs.
This assures functional compatibility.
The runtimes of some operations of the CPU 928A are up to 10 % shorter, however.
The standard FBs for IPs and CPs can be re-used
The following should be noted when using the new modules as replacements:
The new module requires one slot space only.
If it replaces an existing CPU, a front cover must be added to ensure proper cooling.
Alternatively, any other module (see manual) can be plugged into the vacant slot.
The new CPUs require only 0.6 A of supply current.
When configuring a new system or in the case of a replacement, the minimum permissible current load of the power supply needs to be taken into consideration
Hope this helps,
Steve
Thanks for all.
I Try to use new CPU yestday, I can download the program and switch CPU to run, but H1 network does not work in usually.
Hi, I'm looking for standart function blocs SIEMENS S5 6ES5 840-7SG01 for IP262 and standart function blocs SIEMENS S5 6ES5 840-4BC21 for PID CPU 103
1,212
Hello Everyone, i have a machine which has a module "6ES5 262-8MA13" installed Recently this module got defective. now i want to replace it with...
1,433
Hello First...alot of thanks to everyone help in this great forum... Second: I wanna program siemens s5 cpu 6ES5-922-1AA11... what I need for...
2,307
Hello I searched for datasheet "manual" for this module : 6ES5 250 1AA11 ,, and I didn't find anything... Where can I find pdf for this module...
1,823
hello, I have a machine tool HS, CPU-6ES5-921-3W14 (1982) sinumerik is defective, I have in stock the simatics 135U CPU 6ES5-922-3UA11 (1991), I...
1,345
