S5 analog input 6es5 465-7es13
Stikstof
Jun 2008
Antwerp
I need to replace an 8 channel analog input card to the above mentioned card. I have put the dip switches in the right position to let it work as an 8-bit card, but I need some help on connecting the inputs.
The 4-20mA converters are in the first and third slot.
Anyone has expirience with using these 16-bit cards as 8-bit input cards?
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,155
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
265
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
130
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
96
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
115
