S5 power supply
bogdan_cioric
Dec 2005
Bucharest
21
Hello,
I have a old S5 power supply. If i connect this power supply without any modules or cpu it give me the good voltage and all front panel leds are green (all are OK). If i try to connect inside of a complete systems the red leds will light up and automaticaly cpu goes to stop mode.
Please give an advice about this problems.
Many thanks.
bogdan, december 15, 2005
S
Hi i once used to have the same problem and i replaced the power supply with a new one or you can try to open it and take a look inside...
Salut Catalin,
Cred ca putem discuta si in limba romana. Nu imi mai aduc bine aminte daca am masurat atunci cand era conectata in sistem, sunt circa 2 ani de atunci, tot ce-mi amintesc este ca se aprindeau toate ledurile rosii si cpu trecea in stop.
oricum daca ai ceva sfaturi sunt binevenite.
tinem legatura.
merci.
bogdan
bogdan_cioric said:
Salut Catalin,
tinem legatura.
merci.
bogdan
Unde erau situate ledurile astea rosii?
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
222
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
605
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
448
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
247
Long ago, it was often a customer spec to always use a transformer for isolation of the control circuit from the rest of the equipment. For 24vdc...
695
