S5 - S7 Conversion
pouch
Apr 2006
Chester
44
I have converted an S5 program to S7. I want to use FC100, reading in an analogue value, from the S5-S7 Converting Blocks Library. The problem I have is: I do not understand what value is required for the parameter KNKD.The parameter BG is PIW 160 and the pre conversion S5 Channel/Slot value was 0,3.
Does anybody have any ideas.
Regards
Pouch
Have you tried hitting F1 with the block FC100 highlighted in Siematic Manager ? - this should give some comprehensive help. (I don't have access to S7 at present).
I did do that, it does say the parameter takes a word type but I cannot understand what the value should be.
Regards
pouch.
As the original AE460 data type is KY, I would guess that for S7 you would just use a constant word with the values in the appropriate bytes, so for an original KNKD of KY 0,3 the new constant would be W#16#3.
The S7 help isn't very forthcoming about what you do with the channel no. is it? I would assume (dangerous) that with S7 hardware it's always 0?
If it's any help, I have a data sheet for the original AE460 FB31, it's just a bit too big to attach here. If you want a copy PM me an email addres to send it to.
Kevin H
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
229
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
109
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
141
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
112
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
307
