S5 STL Help......please
Sorry there was still a slide difference, you also have to replace the following code from the end.
A(
A F 250.0
A F 250.1
A F 254.0
O F 250.2
A F 253.7
AN F 250.7
S F 251.3
O F 251.1
ON F 253.7
R F 251.3
A F 251.3
= F 254.6
Now you can convert from STL into LAD and into CFS
Rudi
Sorry there was still a slide difference, you also have to Move the red code to the end.
A(
A F 250.0
A F 250.1
A F 254.0
O F 250.2
A F 253.7
AN F 250.7
S F 251.3
O F 251.1
ON F 253.7
R F 251.3
A F 251.3
= F 254.6
Rudi
Fritz_frederix said:
I was trying for you to translate it into ladder. Just remove the NOP 0 at the end of you code and you should be able to switch your rung between STL and LAD.
I've tried in S5 and it worked.
Rudi
Thanks for the advice, I am using a demo version of a third party software:
http://www.softwaretoolbox.com/store/item_pages/itempage_510.asp
Tried what you suggested but it would still not display in ladder. If I play around with it and remove selected parts I can get it to display in ladder. Good for study I suppose!
A(
A F 250.0
A F 250.1
A F 254.0
O F 250.2
A F 253.7
AN F 250.7
S F 251.3
O F 251.1
ON F 253.7
R F 251.3
A F 251.3
= F 254.6
Rudi
Thank you sir.......did as you said and it did exacly as you described!
Hi, I have never done any STL thus far but I now need to do some inderect addressing. I'm trying to write to a DB register by having a drop-down...
1,933
Hi I wondered if anyone could help translate the following two networks into Lad as they don't directly translate. I've had a go myself but need...
20
7,639
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
325
Hi! I am working on a project were we will be replacing an 300 CPU with a 1500 CPU and we are working on migrating / converting code. There is a...
1,079
Hello everyone, friends. I asked a similar question before, and you helped, but I'm very weak in STL and I'm having trouble learning it. What I...
744
