nehe bhimaji
Dear all
I am facing the problem in S5 135U system
In system there is main rack with two ET station
CPU is 948
Problem is
1.My clint switch off the power of the central rack
2.Program is erased due to battery low(No eprom in the system)
3.Replace the battery
4.Load the program in the CPU(The program is tested once and it was working)
5.Now CPU is giving BASP fualt
6.Cheked I stack found LZF error(Programing Error)
As check details of I stack by F7 it says error in FB65
7.As we delete FB65 temeparay then I stack gives another FB error
We are confused beause the program that we are loading was working from last 5 year.
Also we have checked hardware on central rack and ET station by forcing the I/O,s it found OK
I stack images are attached
pls help
CPU is 948
Problem is
pls help
