S7-1200 HMI only showing time in MS
rQx
Oct 2010
Trelleborg
1,051
Hi!
When i display my timers in my HMI it shows in MS. I want them to show in seconds. Is there an easy way or do I have to program it for myself?
Regards
Thank you!
But I just found out that I can edit the HMI tags to do the conversion. Linear Scaling in properties.
Regards
True.
Better keep the scaling and conversions on the PLC side though.
Easier to follow later on when you don't remember what is what.
Much easier and cleaner for someone else to follow as well.
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
743
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
172
I've got TIA portal v18, KTP1200 HMI. I want to add a slider bar (if that's the correct name for it) to an HMI screen. Baslcally, like a...
1,183
See the attached pic ("workflow"). I want to create 2 workflows, depending on if the person who's just logged in is an OPERATOR or an ADMIN...
17
2,504
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
564
