S7-1200 KTP600 alarms
rQx
Oct 2010
Trelleborg
1,051
Hi!
I just ran in to a problem I don't understand.
I've made a program and I use a bit to word converter to the alarms.
I've configured it and all worked fine, the Alarm window was displayed automaticly when an alarm was set.
I worked with my program today and suddenly my alarm window doesn't work anymore. I've checked all configurations I know of but still no luck. I didn't even worked with the alarms when it happend.
The word is set correctly , I see it in the online mode. So the problem must be in the HMI configuration I guess. However , I can't figure it out. The alarm window is set to be activated on all alarms there is in the HMI, and I have tried to make new classes, change classes. Still no luck.
Help? :)
Ok, somehow I've managed to click Lineas Scalling on the word. Unchecking this solved it =)
One more small problem, I use this tread.
My Alarm indication stoped flashing. How do I do?
dear automation experts: i am using a S7-1200 1212c 6ES7212-1AD30-0XB0, with siemens KTP600 comunicating via ethernet. Problem descritpion: -...
2,905
Hello all, The problem I have is how can I load a IP address to the HMI. In my project I have set a IP address similar to the PLC but when I try...
5,931
Hello everyone, I have a system of S7-1200 + KTP600 + router. The questions are which ports needed to be forwarded, are the followings correct...
3,552
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
61
37
