Siemens S7-1200 with KTP600 alarms problem
Joe Hardane
Feb 2012
Ehmej
dear automation experts:
i am using a S7-1200 1212c 6ES7212-1AD3
0-0XB0, with si
emens KTP600 comunicating via ethernet.
Problem descritpion:
- when i trigger alarm A, the alarm log display that alarm A is trigered( very normal)
- i keep alarm A triggered, and i trigger alarm B. the alarm log display alarm B is on, also alarm A is still on( very normal too)
- I remove alarm B, and keep alarm A. the alarm log on the hmi displays that both alarms are still one, after like 30 sec, alarm B is displayed off, alarm A still on.
Is there any solution to remove alarm B more quickly from the alarm log?
(hope my made it clear, koz i
feel it isnt :S)
You're right. it is not clear.
How are your alarms configured? What classes? How are the classes configured?
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
132
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
180
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
290
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,870
