S7 1200 Modbus help please
coasterbp
Dec 2008
Las Vegas
Hello everyone. Thanks for taking the time to read my question.
I would consider myself a advanced-beginner PLC programmer. I've used the Siemens 1200s fairly regularly.
Here' is my dilemma. I've created a program that uses a 1200 and a touchscreen. My client now wants to be able to access as many functions from the touch screen as possible using Modbus. I've never used Modbus, but I've researched quite a bit and have actually set up 2 1200s passing DBs to one another using the Modbus Master/Slave blocks in order to get some understanding on how it works. The main problem is that my client will not be using another PLC, but a 3rd party HMI software to monitor and set values. I've set up my PLC to act as a slave, but how do I address everything so that he may write/read values in my PLC?
Does this make sense?
Thanks again for your time and help.
-=coasterbp
I have 3 control panels made by an OEM, they are all identical and have a Siemens S7-1200 PLC with a Siemens CB-1241 Modbus card talking to 2...
4,562
Hi ! Everybody ! Please..help me about communication between S7 1200 and inverter or any varispeed inverter had MODBUS support by module CM1241...
20
11,182
Hello everyone, M using micrologix 1200 and it is connected to net-aic using pm02 cable, then net-aic is connected to my laptop using pm02 and a...
3,952
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
268
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
389
