S7-1200 programming from SD Card
boros000
Sep 2012
Sf.Gheorghe
29
Hello,
I have a short question.
I have an S7-1200 at the other side of the world. I have to program it.
What I think:
- I need a Siemens SD card(must be siemens)
- I need a card reader (regular card reader)
- from TIA I transfer to SD card the project
- I send with post the card
- They introduce the card in the CPU
- Program transfers automatically
Am I right?
Wich step is incorrect?
Thank you.
All Correct.
But then You will have no possibility of changing running program.
I think PC with TIA portal installed and TeamViewer will make the job better.
OK. Thank you or your answer. Very short and precise.
They don't want to buy TIA and we don't want to visit them, so we send the program by card, if they want a modification, we send and other card :) and so on.
If you want them to put the card in to the PLC, then the program is transferred, then they remove the card, then you must set it to type 'Transfer'. If you want to send the card and it lives permanently in the PLC, then you must set type to 'Program'. Make sure that the Firmware version of your program matches the Firmware version of the PLC.
Just to cause confusion you have to set it to Transfer mode after you copy the program to it. I was very confused for a while because I was setting it to 'Transfer' beforehand and then it gets reset to 'Program' mode when you copy a program to it.
Hi, The MicroLogix 1200 has a Com 0 port and a "HMI/programming port". When looking at the PLC, there is a port on the left side and a port on...
1,750
Greetings, I am an Allen-Bradley programmer who has an opportunity to work with some Siemens equipment (S7-1200). The discreet stuff is pretty...
2,786
Hi I need helpp in writting my PLC program: I m new in siemens PLC programming and TIA PORTAL here is the topic: I have to write a PLC program...
1,340
In micrologix1200 I have only one communication channel so that I do not unable to configure the PLC with Modbus rtu slave driver without losing...
4,268
Guys, i need your help.. Im using S7-1200 CPU1212c AC/DC/RLY and for my project, i want to learn how to program this in analog inputs.. Im using...
2,458
