S7-1200 to wago 750-352 ETHERNET Fieldbus Coupler
Mar 2009
Leeds
49
Any one have any idea what would be involved is getting a 1200 to use the io on one of thease wago 750-352 over ethernet.
Googling has not currently come up with any how too's or examples.
I was hoping it would be be similar to profibus io and a gsd file in the hardware config and job done.
I found the alternative model for profinet just after I posted last time and this does look like the easy way to go by configuring using a gsd file in hardware configuration. Unfortunately the wago 750-342 has not been specced by us and is an existing system a number of which have already been built. We are trying to modify an existing s7-1200 plc system to control the outputs on this wago 750-342.
So is it possible to write my own tcpip coms code to do EtherNet/IP communications to this module to a set number of digital input and output cards.
This module appears to use either modbus tcp or EtherNet/iP.
I've been looking into Modbus TCP on the S7-1200 and in step 7 V11 there are some functions to do modbus tcp. There's a MB_SERVER and a MB_CLIENT function. Which one or both do I need to be looking at.
Trying to configure some wago profinet IO using TIA portal. I've not been able to use any of the wago ethernet utilities to find the thing over...
6,562
How to configure the DPRD_DAT and also DPWR_DAT if the slave is non siemens I/O and does not have any hardware ID(system constants) and just the...
3,476
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
258
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
