DPRD_DAT, DPWR_DAT with S7-1200 and Wago
qwemx
Jul 2017
Earth
195
How to configure the DPRD_DAT and also DPWR_DAT if the slave is non siemens I/O and does not have any hardware ID(system constants) and just the profibus address and input output area .
Wago slave has the Input address 7 to 16 and output from 7 to 11. It has a Profibus address of 40
I have to get 10 bytes from this Wago slave device to the S7-1200 CPU
so how i configure the DPRD for this
from siemens help on DPRD_DAT
"LADDR = Hardware ID of the module from which the data is to be read.
The hardware ID can be found in the properties of the module in the device view or system constants."
Wago has no hardware ID
I have one master and 3 wago I/O slaves and also 3 1200 cpu (slave)
is it necessary that I use the DPRD_DAT only in master , can I use it inside one of the s7-1200 which is slave to get data from wago slave
when i try to do this i do not see the hardware ID in the list
The IO addresses are available in Master(s7-300) process image but not in the S7-1200, If I make logic in Master then I can directly use the IO ADDRESSES because these slaves send data to the Master process image - but I have to make logic in s7-1200 PLC so need to transfer the information from the Wago slave to s7-1200
Would like to know what is the reason for setting up the system like that, with 1 Profibus master, and many slaves, and the S7-1200 Slaves are to be functionally controlling the Wago slaves.
There are a couple of ways to share IO, but it always requires one DP master to be the hub of the communication. This defeats in my opinion any reason one could have for distributing the "master" functionality over several CPUs.
Simpler would be to just have 1 CPU control all slaves.
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,464
SFC 14 and SFC15 giving error : -32591 I am using the library from ABB for the drives to run ACS800 from S7-300 CPU(6ES7 315-2AH14-0AB0)...
949
Hello, Is it possible to use the RS logix 500 software to mimic any type of commands that the 1764-DAT unit on the ML1500 plc uses? I have a...
1,225
Hey, Iam trying to open an E-Designer project. I don't have the .mpa file. I only have .dat Question is, how can I restore the .dat file? Do I...
2,778
Hi What are the rules for choosing a heidenhain EnDat encoder? I have a broken encoder on my Baumuller servo motor need to be replaced...
1,374
