DPRD_DAT and DPWR_DAT SFC 14 and SFC15 giving error : -32591
qwemx
Jul 2017
Earth
195
I am using the library from ABB for the drives to run ACS800 from S7-300 CPU(6ES7 315-2AH14-0AB0)
Library link is
https://search.abb.com/library/Down...LanguageCode=en&DocumentPartId=&Action=Launch
GSD
https://search.abb.com/library/Down...anguageCode=en&DocumentPartId=2&Action=Launch
I am getting an error in SFC14 and SFC 15 instructions - rest all is Ok
I have created a separate small program just having the DPRD_DAT and DPWR_DAT to show the error - it was causing the library to not work - How can I fix this issue
This library is for TIA Version 13 originally and I am using V16 TIA it was upgraded when I opened it and this error is also happening when the instruction being used in separate program.
Screenshot_2.png Screenshot_3.png Screenshot_4.png Screenshot_5.png Screenshot_1.png
Thank you!!!! I think I realized what I am doing wrong I have to start transfer from byte 128 to byte 147 which will be 20 bytes.
PPO5 is defined as 4PKW (read/write acyclic) + 10 PZD (read/write cyclic), a total of 28 bytes reserved for exchanges with the drive.
4PKW
120 121 122 123 124 125 126 127
10PZD
128 129 130 131 132 133 134 135 136 137
138 139 140 141 142 143 144 145 146 147
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,458
Hello, Is it possible to use the RS logix 500 software to mimic any type of commands that the 1764-DAT unit on the ML1500 plc uses? I have a...
1,222
Hey, Iam trying to open an E-Designer project. I don't have the .mpa file. I only have .dat Question is, how can I restore the .dat file? Do I...
2,774
Hi What are the rules for choosing a heidenhain EnDat encoder? I have a broken encoder on my Baumuller servo motor need to be replaced...
1,370
How to configure the DPRD_DAT and also DPWR_DAT if the slave is non siemens I/O and does not have any hardware ID(system constants) and just the...
3,472
