RMA
And oh! what kind of operator interface can I use with the FM352-5? Will the TP series work?
That could be a bit of a problem, it may be possible, but I doubt if it will be easy to add some sort of operator interface without also having to add a 300 CPU, which bumps up the price significantly. To do without the CPU, you'ld probably have to for a home brewed PC application using VB, which probably cost even more in man-hours than going the 300 /Step7-lite route.
