S7-200 Communication problem
pjadha
Feb 2014
pune
22
Hello someone please help me. I am trying to connect online on S7-200CN CPU- 226 CN. I have Micro/win software installed in my Laptop. I have MPI communication cable. I set my PG/PC interface on PC Adaptor(MPI) cable with USB setting. Then I double clicked to refresh (In communication window) but I got error message every time that is "Port could not be opened or is being used by another application." I have total 2 ports on PLC PG0 & PG1. I tried with both ports. Also I tried restarting PLC power but same error is occurring. Please support me.
Siemens Simatic S7-200 uses PPI interface, not MPI.
Some S7-200s however are capable of communication through MPI as well, but coming out of the factory you should use PPI first to configure the possibility to communicate over MPI. Default factory setting is PPI.
Modern MPI converters can also deal with PPI, so in case you have an adapter of this kind, simply set it to PPI first and then try to connect to the PLC.
CN versions also have some other problems: I believe that if Chinese is not installed as one of the interface languages for your Step 7 MicroWIN you can't do anything with the PLC. There were some thread about this on this forum.
Thanks Mr.jvdcande for your valuable reply. I have PC Adapter model no - "6ES7972-0CB20-0XA0" Can this work as PPI interface? I checked in siemens manual but I didn't find anywhere that I can use this MPI adapter as PPI too. So as per your experience please tell me can I use it for PPI communication. Also what is exact meaning of error "Port could not be opened or is being used by another application."??????
My CPU is 226 CN.
6ES7972-0CB20-0XA0 is an MPI adapter and cannot be used as a PPI adapter.
PPI adapter PN is 6ES7 901-3CB30-0XA0.
Hi, :p
This cable 6ES7972-0CB20-0XA0 work with simatic 200/300/400.(works even with cpu 226 CN).
PG/PC interface -->PC adapter(ppi) --->proprety -->com=USB.
Hope this help.
Thanks Mr.jvdcande.Your solution works. Now I am able to communicate to S7 200 CPU 226 CN with MPI adapter ("6ES7972-0CB20-0XA0") by selecting PG/PC interface -->PC adapter(ppi) --->proprety -->com=USB. It is working good. No issue.
Hello Sir,
I have S7-200CN CPU226CN. I have Micro/win software installed in my Laptop. I have MPI communication cable. I set my PG/PC interface on PC Adaptor(MPI) cable with USB setting. I want to take backup from PLC to my Programming Laptop (Backup Upload). I done everything and reached to backup uploading finish but at last moment I got some windows error and stopped backup uploading process. I tried with different laptop with different Windows XP OS but I am failed.
Can you please help me in this regards......
The error is
"Siemens STEP 7-Micro/WIN 32 has encountered a problem and needs to close. We are sorry for the inconvenience."
I think you should use Micro win SP9.. check your PC/PG in control panel then choose Adaptor PPI ....then refresh your communication...edit 19200 kb/s rate by 9600kb/s
normally...the driver of adapter will be auto recognized...but sometime u must be installed the driver (Adapter USB MPI A2)...
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,625
Hello Friends, I'm facing a communication problem between the PC and S7-200 PLC(CPU 226) via Micro/WIN software and USB-MPI adapter, the settings...
1,530
Hi, Recently I was forced to replace a S7-200 CPU 226 on an old machine, which was defected. Unfortunatelly the old cpu was password protected by...
1,701
Hello Guys, I'm using S7-200 PLC to run Conveyor System. I have a problem in communicating S7-200 PLC when the conveyor system starts to run. I...
1,711
Hello, I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC. When...
1,445
