S7-200 Communication Problem
apolionman
Nov 2013
Dubai
47
Hello Guys,
I'm using S7-200 PLC to run Conveyor System.
I have a problem in communicating S7-200 PLC when the conveyor system starts to run. I can't no more read the PLC or the communication fails.
but when I use Laptop to communicate S7-200 while the conveyor system is , running the communication is good.
Is there a problem in my wiring connection? or other problem in my system?
Will you please help me with this? :(
Strange... Have you checked the voltage? put your meter on the power to the CPU and see if it drops when the conveyor starts, it may dropping low enough to stop your coms for just a sec then MicroWin will error out
Thank you for quick reply.
I tried checking the power of the CPU and it's okay.
There might be a problem in a ground connection of the CPU.
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,625
Hello Friends, I'm facing a communication problem between the PC and S7-200 PLC(CPU 226) via Micro/WIN software and USB-MPI adapter, the settings...
1,530
Hello someone please help me. I am trying to connect online on S7-200CN CPU- 226 CN. I have Micro/win software installed in my Laptop. I have MPI...
11,423
Hi, Recently I was forced to replace a S7-200 CPU 226 on an old machine, which was defected. Unfortunatelly the old cpu was password protected by...
1,700
Hello, I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC. When...
1,445
