Communication problem with S7-200 and TP170b panel
gdalianis
Jan 2008
Greece
17
Recently I was forced to replace a S7-200 CPU 226 on an old machine, which was defected. Unfortunatelly the old cpu was password protected by the builder of the machine, but luckily I had the program printed on paper so I write it down again on microwin and uploaded to the new CPU. Unfortunatelly I can not establish connection with the CPU and the TP170b mono panel which is used at the machine for some timers and selection of recipes. The message 140001 (Disconected PLC_..) appears on the screen of the touch panel. I have checked the cable and seems to have no problem. I change the baund rate at the ports of the cpu, still no effect...The cpu is connected to TP though the IF 1B port with DP/MPI protocol. I have searched for a solution for the problem at the net, but I did not find anything usefull. Also I have to mention that the version at the new CPU is 2.1, which is not an option at the microwin (it goes up to vesrion 2.0), but the program is uploaded fine at the cpu, I can check by downloading back the program to the pc. I am very niewbie at programming CPU's and I can not think of anything else that I should ckeck, any help to what should I look would be very usefull.....
Thank you
S7-200
Dear gdalianis,
It sounds like the HMI is programed to access the PLC at an address different than 2 (Address 2 is the defaualt address).
You want to try other PLC addresses(Communication Ports Setting), it totally depends on your luck, but worth trying.
Regards
Hagos,
Dear gdalianis,
Regards
Hagos,
Ok, I think I will give it a try, althought I have already tried adresses 1 and 3...
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,625
Hello Friends, I'm facing a communication problem between the PC and S7-200 PLC(CPU 226) via Micro/WIN software and USB-MPI adapter, the settings...
1,530
Hello someone please help me. I am trying to connect online on S7-200CN CPU- 226 CN. I have Micro/win software installed in my Laptop. I have MPI...
11,423
Hello Guys, I'm using S7-200 PLC to run Conveyor System. I have a problem in communicating S7-200 PLC when the conveyor system starts to run. I...
1,711
Hello, I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC. When...
1,445
