s7-200 input test
bouklas
Mar 2007
Thessalonikh
Good morning everybody!
i have one s7200(siemens), is there any way to test its inputs without put test voltage in each of them?
Thank You!
Thank you.
Maybe i have one usefull information
I'm not sure about that i did't check it
somebody told my that in plc diagnostics, is easy to see if an input is burned.but only if the input transistor has a problem, in other cases only with voltage testing we can see if we have proble.
Good day to all.
Thank you!
Hi every one am working on this machine ,where there is a motor that rotates an arm with high speed when the arm reaches the sensor the motor...
2,011
Hello, We have the following DI card that can accept 1,2 and 3 wire DI's ( 6DL1131-6BH00-0PH1). We plan on installing this card for use with a...
1,487
I have an allen Bradley micro running a fan in an industrial paint mixing facility. The input fuse is 3a. The system will run fine for a bit and...
1,992
Hello How can I wire this sensor to S7-200 (cpu 226) ? And what is this power supplies indicated in red arrows in the attached image ? must I...
2,044
Hi, We have a dosing system that uses the 224XP REL 02.01 CPU. It has a encoder input wired to input I0.1 and monitors the position and speed of...
2,798
