s7-200 plc simulator...
cavusogullari
Dec 2004
21
I'm using s7-200 simulator to simulae my projects. but i cant find how can i add analog input/outputs to simulation... is there anyone can tell me how?
hi,
After selecting the CPU type you will see the basic modul and some other extension position you double click the fist one and you select one analog modul from the configuration moduls window .
Good luck.
BOUHLEL
s7-200 simulator
you will find inclose the S7 200 simulator .
if some help is needed please send me your email
Best regards
in this simulator if u adjust cpu clock time by manually (for example to 19:59:57) clock's hour segment doesn't increase; instead of it minute...
2,190
i've been using s7_200 simulator (canal plc) for a long time. it was useful for to simulate basic functions of s7-200 plc. but recently my...
8,081
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
59
35
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
105
