s7 200 PLC with a TS adapter
rigicon
Aug 2009
kent
415
Hi fellow Control Engineers,
I have a s7 300 plc which I communicate with a MPI to usb and a Ts adapter.
I have a s7 200 plc which I communicate with a PPI to usb but I cannot get it talking with a TS adapter.
What I really need is a PPI to DB9 RS232 adapter. Is there any other way I have a TS adapter and a TSA ][ modem.
The reason for all this is I have a serial device server that gives me a virtual com port over ethernet to the PLC - works great for S7 300 now for S7 200. Any Ideas Please?o_O
Connected profibus cable with terminators on either side the same one I use for programming S7 300. Connected it up to s7300=works then to s7 200=not working.
Then to S7 300 & S7 200 found S7 300 in Simatic manager 5.4 and talked.
In Step7 V4 micro/win found 126 unknown nodes when connected to S7200 then on to S7 300 = not talking to S7 200
In Step7 V4 micro/win found 2 unknown nodes when connected to S7300 then on to S7 200 = not talking to S7 200
M.W. I did like your idea made sense.
I understand that PPI = point to point S7 200 and MPI is multi point S7 300. I thought they were both 2 wire 485 with the profibus protocol on top.
I think the only way is to try source a RS232 tp PPI converter. Help if you can?
Rigicon, my thought was to add a S7-200 DP Module (EM277) 277-0AA22-0X0A, this would then allow you to set your comms in microwin to DP and then access through the profibus cable.
Unfortunatly I don't have TS adaptor to try.
M.W (www.ac-sys.co.uk)
That would probably work. £173 from RS 434-1866. Cheers.
Or a RS232/PPI interconnection cable RS 468-5829 £93.
I am sure I had a rs232 round here before I updated to USB. Could change my serial to ethernet to USB to ethernet.
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
49
30
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
233
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,907
