S7 200 question
Yes, but we won't at least for free.
It isn't our job to write others homework PLC programs.
Tell us which part you have problems and what you have allready done. Then forum members can help you to make it work.
Shame it is not an S7-1200 as the trace facility provides an excellent method of displaying results for this type of problem.
It took me more time to generate the pulse trains to test this compared to the time to code the sequence.
thanks for taking care of the question
[/url][/IMG]
My writing program is running but I'm not sure on it
O0.0 has two rungs the write to it; only one of them will be active at any time. Perhaps one of those O0.0 tags should be something else, but there should not be two --( )-- instructions writing to O0.0.
[Update: removed mistaken statement about C1]
That image is ambiguous, but what I see is this:
  • I0.0 is start, and I0.1 is stop; both are normally open
    • All outputs are 0 when the process is stopped
    • Outputs only change when the process is running, i.e. between I0.0 becoming 1 and I0.1 becoming 1
    • So OP's first rung, similar to a Start/Stop circuit (see here), is a good start ...
      • but I do not understand why C1 is in that rung,
      • because when C1(.Done?) is 1, the process will be stopped,
      • and I think it should only stop when I0.1 becomes 1
  • Once, and as long as, the process is running, on the first rising edge of I0.2,
    • on O0.2 becomes 1
  • On the seventh rising edge of I0.2,
    • not eighth - @LD maybe has a typo?
    • O0.2 becomes 0,
    • O0.1 becomes 1,
    • and O0.0 is always the opposite of O0.1 at this point and forward, until the process is stopped with I0.1
  • The process then toggles between the next two steps, [Step A] and [Step B] , until the stop occurs (I0.1 becomes 1)
  • [Step A] On the next rising edge of I0.2
    • O0.1/O0.0 become 0/1
    • the process starts ignoring rising edges of I0.2,
    • and starts responding to rising edges of I0.3
  • [Step B] On the second rising edge of I0.3,
    • O0.1/O0.1 become 1/0,
    • the process begins again to respond to rising edges of I0.2
    • and starts ignoring rising edges of I0.3
    • And goes back to [Step A]
Again, there are ambiguities there since we have only the trend diagram, but that is what I think the process is supposed to do.
I took a different approach and used a Step counter to keep track of the rising edges that trigger the various output changes.
This is the code for a TIA S7-1200/1500 plc but you should get the gist:
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
We have a Simatic S7-200 6ES7 214-1B01-0XB0 (relay output) that has a bad output. I want to reprogram to use an open output. I still have an old...
1,196
Hello all, I've been working on a siemens PLC system using an S7-1200 and a KTP400 Basic HMI. Essentially this system takes in some setup...
1,387
Hello, Looking at the paper version of a chinese S7 200 Smart program that I will need to manually convert I have a question about the use of...
1,381
What the heck is this "P", and how is it used for this counter? ....You can't search a "P" in the manual. Thanks!
1,802
