S7-200 to a printer
suaj001
Nov 2011
california
Hello,
Am new to plc programming just a couple months into it and got a few questions about being ale to print with a s7-200 plc. I've read alot of post and have the tip019 and i get how it works but what am confuse about is, those this program only print those signal words per page each time u press the I0.x button or is it consecutive.
Also the program am trying to write consis of taking different pressure measurement and flow and printing out the results. I have it set up so it will print like this
"Pressure # x Flow # x" which is probaly the way i want it. What am stuck on is trying to get the different measurement for pressure and flow to save the variable and print using the same code. It would be 21 different measurements for pressure and flow.
Any help would be a greate help hopfully i explained it enough...o_O
Hello, S7-200 is installed with dot matrix printer. its printer is not working. now I have changed the printer. Problem in new printer is that...
218
I have built my first 3d printer. I used a k8200 kit that was gifted to me and gave it a z-axis upgrade and direct drive extruder. I am in the...
1,103
Hi everyone, Does anyone have a guide on how to communicate a zebra printer with a s7-1200 plc via TCP using TIA portal?? or any advices on what...
1,872
Hi, I am having a right nightmare of a time. I have never programmed a Zebra printer before and need some help from you professionals. I don't...
2,895
Hi, I need help about how establishment communication between a Siemens S7-1200 plc and a Zebra ZM-400 printer over Ethernet. I am using Tia V13...
2,711
