S7-200 & WinCC Flexible
CharlesM
Aug 2005
Arkansas
1,129
I am just getting started with S7-200 and I am having trouble with the VW data blocks. I am trying to setup a buffer bit trend into WinCC Flexible. I have done this many time with WinAC (300/400) I would setup a DB with an array of ints. The problem is I don't know how to do an array on S7-200. So I have in Flexible the trend buffer starting at VW1000 and I have an array of 360. Then in the 200 I have VM1000 3,3,3,3,3,3 etc for 360. Is this not the way I should do it? It seems to work fine up to 25 then Flexible gives me an overflow alarm. I have not had much luck finding out what the overflow alarm is but I think its telling me that I am writing to a memory location that is not on the plc.
Hello! I want to save production data in a list form. I have three variables that I want to save: Product, weight and time. I want this to be...
3,862
Dear all, I nead to access parts of structures from s7-1200 plc in wincc flexible running on PC. My problem is that plc programm is done by...
2,953
I have win-cc Flexible 2008 and s7200 plc. I successfully programmed it via micro-win, but when I tried to connect it to win cc there was no...
3,309
Dear All, Is there a best way to do it one faceplate for 200 pcs of objects in WinCC flex RT? In my case, i have done with script for all 200...
2,074
Hello all, I want to Control & Monitor 8 different S7-200 CPU 226 PLCs through Wincc Flexible SCADA. I am trying to communicate through...
7,043
