S7-200CN and Wienview6071iP
jbergsma
Sep 2020
Ontario
Hi
I am working on a small project with an S7-200CN CPU 224 and a Weinview6071iP. I am new to both of these platforms. I am wondering if anyone has any experience with this combination. The HMI has an S7-200 driver and appears to be able to access the PLC's memory directly. I am just wondering if there is something I have to set up in the PLC to give the HMI access to its data. Below are the communication settings in of both the PLC and the HMI
Cheers
You are looking in the wrong place for setting the PLC Ports. In the main MicroWin page go to System Block / Communication Ports and check that the Port address there is what you want. Haven't used WeinView, but see if the 'Device default station ID' refers to the PLC and not the HMI, I would expect you would have to set the HMI Port Address somewhere. There are two Ports in my picture because it is for an S7-226.
Hi Was wondering if anyone may have had any experience connecting to an s7/200CN plc with Step7 MicroWin Smart. Cant seem to get the connection...
1,296
I am having 4 nos. of S7-200 CPU224 XP CN. I am trying to download the program in it. but not able to do so in 2 nos. of PLC's, where as in other...
2,062
Hello every one i am communicate the tp-177micro with s7200cn with(mpi cable) but it not communacate each other. my connfigratuino is rong or...
2,085
