S7 300 analog output checking
vishnu101090
Mar 2014
cochin
I am validation engineer. currently i am working on S7 300. i want to know how to check the analog input and output ? can i take a screen shot evidence while checking?
PLEASE HELP
You need to get the automation guys to provide test sheets for each analog
hi i am using s7-300(CPU 313c). when i try to use FC106 unscale function, i can change IN manually but there is no effect on OUT. i wrote PQW752...
1,611
Hi guys, I have CPU S7-300-313C ( Cat No - 6ES7-313-5BE00-0AB0) DI24/DO16 and AI5/AO2. when I am trying to configure and use the AO channel PQW...
2,566
I need help sending an analog input (temperature) to an analog output (4-20ma)?
19
4,320
Hi Quick question. Is there 4mA at the output on the analog card when it is configured in the HW and the card has 24VDC? Or does the output have...
1,416
So I am trying to control the speed of a motor with a Siemens S7-300 PLC. I have an analog input card as well as an analog output card. I am...
7,100
