s7-300 analog output
amrhk
Jan 2018
iran
hi
i am using s7-300(CPU 313c). when i try to use FC106 unscale function, i can change IN manually but there is no effect on OUT.
i wrote PQW752 in OUT for analog output.
I think your problem is really the SCALE function.
The value being written to MD2 on your network 2 should be between 0 and 300.
Is MD2 used elsewhere? Or forced perhaps? Remember that when forcing Real values with a Siemens PLC you need to type the .0 at the end of the number.
Welcome to the forum!
I think your input values are fine, however, your are writing a status word (2 bytes) to MW1 and then a real to MD2. Second network, your status is MW2. These overlap.
If you use MD4 (assuming it is available) it should work.
Rule of thumb, use even numbers for W and D values.
Thank you.
I changed the address's and it works properly. But still I can't view the value of PQW752 in the block, I can mesuer the output voltage with multimeter after running PLC.
Hi guys, I have CPU S7-300-313C ( Cat No - 6ES7-313-5BE00-0AB0) DI24/DO16 and AI5/AO2. when I am trying to configure and use the AO channel PQW...
2,562
I need help sending an analog input (temperature) to an analog output (4-20ma)?
19
4,317
Hi Quick question. Is there 4mA at the output on the analog card when it is configured in the HW and the card has 24VDC? Or does the output have...
1,413
Hi, I am validation engineer. currently i am working on S7 300. i want to know how to check the analog input and output ? can i take a screen...
1,745
So I am trying to control the speed of a motor with a Siemens S7-300 PLC. I have an analog input card as well as an analog output card. I am...
7,090
