S7 300 and S7 200 CPU Communication
S7-300 To Communicate with S7-200
You need to install an EM277 card at the S7-200 side, then your S7-200 will act as a DP slave.
Hi Does anyone know of a gsm modem with TS-adapter that works with both 200 & 300 cpu's? My requirements is that it should be easy to install so...
2,913
Hi.In the S7-300 plc, DB100.DBB10, whose data type is byte, is transferred to db23.dbb10, whose data type is bool, with the move command. This...
809
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
763
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,780
Hello everyone, I have a SIMATIC s7-300 CPU 313-2 DP[ORDER NO:6ES7 313-6CF03-0AB0] with firmware version 2.012. I want to update the firmware with...
2,069
