S7-300 PLC CPU 314 - First Scan Bit
SelimHS
May 2018
Denmark
Hello Everyone!
As the title suggests, i would like to know how to program a "First Scan Bit" in S7-300 PLC CPU314. I made a sequence with 3 cylinders, which you can see in the file i attached. You will also notice in the file, that there's a first scan bit in the beginning. This is what i would normally do, if i was using a S7-1200. But sadly, there's no first scan bit in S7-300. You have to make it yourself.
I read something about OB100 (warm restart) which is the only thing you can use in S7-300 for a "First Scan Bit". The problem is, i'm confused to what should go inside the OB100. What should i put inside? :(
I should also mention, that i'm a beginner. So don't be too hard on me. :unsure:
You'll have to dig this a bit more, but the first OB being run when the PLC starts is OB100 (or similar, I think 100 is warm restart). Inside that OB, set a bit to 1.
At the end of OB1, reset the bit to zero.
Though I would think that OB1 has a first run bit, but don't quote me on that.
Same bit address on all instructions:
1st rung in OB1:
--|/|---------------------(S)--
last rung in OB1
--------------------------(R)--
Or this for the last rung in OB1:
---| |--------------------(R)--
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,658
Hi guys, looking for some advice from someone with some siemens hardware experience. Im a student considering buying a siemens plc to practice...
5,050
Dear Friends, I have a S7 300 (318-dp 2)P.L.C. I need to connect a touch panel TP 270 via wireless radio modem. My problem is the transmission...
4,101
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
220
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
691
