S7 300 RS-232 serial port
benji
Oct 2008
syria , Aleppo
72
I was wondering if I can send/recieve data between PC AND PLC through the COM port
are there blocks in Ladder logic in step7 thats does the job (send/recieve) ?
thanks in advance
thanks for posting the links but i dont see anything there about RS-232
can you refer to it?a manual?
and the whole cpus in communication are just the 314 series
doesnt the 313 has rs232?
Ops.. You need CP341 Com port for RS232C to your PLC.
Maybe better is CP343-1 Lean unit for Ethernet (around 500€).
I don't know if there is something for MPI. MPI is RS485 as Profibus DP.
Does anyone know the pinouts? one side is round 8 pin, andother is D-sub 9 pin.
2,792
Hi all. We have S7-300, RS232-MPI Converter, TIA PORTAL v13 and it's not working. The driver of the cable is from prolific, and it works well with...
6,578
Hi, I am trying to download a program onto the a PV550. The program was initially written for a PV300 with DF1 communications. The PV550 has...
2,333
I am a new user to Rockwell products. I am trying to connect a Panelview 300 Here's the specifics of the system. Panel view 300 p/n 2711-K3A5L1...
17
16,047
Good Day All: We have a radiation dose calibrator (measures radioniclide activity) which connects to a CP340 RS232 module on a Siemens S-300...
4,597
