Good Day All:
We have a radiation dose calibrator (measures radioniclide activity) which connects to a CP340 RS232 module on a Siemens S-300 PLC. A custom 'activity dispensing' PC application program (COMECER, Agatha Timotheo) speaks to the PLC to take readings from the radiation dose calibrator and displays it in the user interface. After a series of power failures, we found that no reading updates appeared in the user interface (just 0.000 - no noise indicating any electronic activity). We first thought that the radiation dose calibrator may be faulty. Replacement of the device indicated no change - still no reading updates. A question: With the application control program functioning OK, is the CP340 RS232 module faulty/broken.
The CP340 RS232 module shows the following: SF is ON; TX,RX is showing no 'activity'. Surely, these LEDS should show some 'activity' if the radiation dose calibrator-PLC-PC user interface was functional. We assume standard RS232 communications.
I am not a PLC expert or an electronic professional. Any advice will help!
In Appreciation....
In Appreciation....
