S7 312 with CP340 rs232, send message to an Epson cash display?
morgan1234
Nov 2013
Gothenburg
Hello.
I´m a plc-rookie and really need help.
I have a Siemens 312 PLC , CP 340 rs232 card and an Epson cash display.
I want to send a counter value and a count down value from a timer.
I´ll explain: A timer starts to count down from ex. 60 seconds, and a counter count number of positive edges from an input. After 60 seconds the counter stops. I also want to send some text message to the display it has 2 x 20 characters.
Very easy if you know how to do it :confused:
I have configured the hardware and it works correct, but I don't understand how to use FB3 in the editor? I've read the pdf-manual about the CP340 card, but I don´t understand it. Because when I activate the function the PLC switch to stop mode.
I need tips how to configure the FB3 and if I have to configure the instance data block?
If you take your time to explain, please explain in a level to a 6 year old child 📚
Here is my hardware config:
PLC CPU312 V1.1 312-5AC02-0AB0
Com. CP340 340-1AH01-0AE0
Display Epson DM-D105
Manager V5.5 + SP1
Best Regards
Morgan
Hello my fellow plc masters. I have come to ask you again :D Lets start the story. A few days ago i've made a post here about a s7-300 plc and...
19
4,579
Hi! Greetings, I've been trying to use the PLC M221 to control and read the variables from the VSD ATV312 through Modbus RTU, which is something...
1,605
Dear all, My CPU312 is in RUN state, RUN and DC5V LED's are green. Still there is no input or output. CP341 (RS422/485) is also installed in a...
1,058
As you know, Schneider is phasing out the 312. We have had problems w/ the 320 following the decel ramp. Anyone else? Also, we have had to adjust...
1,531
Hello everyone. I'm trying to communicate a Controllogix L36ERM with a 1769-SM2 Modbus module to a Schneider-electric Altivar 312 Modbus motor...
2,487
