CP340 RS232 making connection to Balance
userxyz
May 2002
any
2,768
Hi
I have a CP340 connected to a balance.
Balance to hyperterminal works.
Balance to CP doesn't work, RXD blinks, but no data retrieve
Any ideas ?
Regards,
COmbo
Settings
The balance to hyperterminal:
9600bps, even parity, 7 databits, 1stopbit, Hardware handshake
The Settings in de CP340 card:
No values when checking the PIB's.
When I set Automatic RS232 signals on in the transfer tab, then the RXD led blinks... the Ican receive data ? But even then I don't see any ASCII data in the PIB's...
regards,
Combo
Hi Kalle,
I cannot find DSR and RTS on the balance.
I tried the follwing today:
- Balance to Hyperterminal:
9600 bps, 1 stopbit, 7 databits, hardware control
The balance can do handshake in hardware control or software control, not without. This works, data arrives in the hyperterminal.
- Hyperterminal to CP340 (read with P_RECV)
9600 bps, 1 stopbit, 7 databits, No Hardware control.
When I set No Data Control in Hyperterminal as well, then I can Send data to the connected DB in S7, NDR becomes high every succesful received char.
Balance connected to CP340:
- The RXD led only blinks when I set RS232 automatic under the tab transfer. But I cannot read data Error on P_RCV block, status 818.
hmmm
Do you have an idea ?
thanks
Do you use the BRECV to read out the data?
Edit: And you could try to use No dataflow control, and to strap DTR/DSR and RTS/CTS on the balance side.
Kalle
Sorry, my only experience with S7 and serial is with the CP441 some 10 years ago. I remember using the Modbus RTU, RK3964 and ASCII protocol, and allways writing/reading with BSEND/BRECV.
Don't know if these B-blocks are usable with the CP340.
Kalle
Hello. I´m a plc-rookie and really need help. I have a Siemens 312 PLC , CP 340 rs232 card and an Epson cash display. I want to send a counter...
2,609
Hi folks, I could really use some help - I am trying to connect CP340 with my PC by RS232 protocol. I need to send some characters to PC from...
1,902
Hello, I have 3 balances connected on RS232 at very low speed (2400bps). All 3 make good communication. But, after a day or so, 1 or more...
3,717
Good Day All: We have a radiation dose calibrator (measures radioniclide activity) which connects to a CP340 RS232 module on a Siemens S-300...
4,594
Hallo, I have Tia Portal V16 and I'm upgrading an older machine. That machine has a component running on rs232. The machine has still the old...
960
