S7 Hardware revision compatability
Jun 2007
Oxford, UK
163
Hi everyone,
I was wondering if there was a table or chart available that allows you to see which revision part numbers are compatable with older parts and if the HW config needs to be updated with the addition of the new part whilst keeping the same operation?
Im pretty tired at this point so if that makes no sense i apologise.
Cheers
bmw_apprentice
http://support.automation.siemens.com/WW/view/en/23183356
Thanks for the swift reply!
As far as i can tell thats for updating the actual HW catalog. What i am trying to determine, and ill use an example, is if i had a failed module eg. 6ES7 138-4FA02-0AB0 and i went to stores and they didnt have that particular part but they did have 6ES7 138-4FA03-0AB0 how would i know if this is compatable with the old system and are there any changes i need to make. I say this are parts that we are buying old revisions for that can simply be replaced with newer revision models.
Does that make sense?
Cheers
bmw_apprentice
http://support.automation.siemens.com/WW/view/en/24480983
This module replaces the predecessor version and is spare part compatible.
The following additions and improvements have been introduced with the module:...
Compatibility
The new module is spare part compatible with the predecessor versions of the module.
This means that in the case of a replacement of an old version against the new version it is not necessary to make a change in HW-Config of STEP 7.
That is exactly what i need! How about for other parts? Is there an easy way we can reference this for other parts?
I am thinking of rolling this out to all our engineers so i need a fairly robust system.
Cheers for the response.
bmw_apprentice
89
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
212
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
494
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
171
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
140
