S7 High speed Counter.
roxtech
Mar 2008
Township Lahore
198
I use cpu 313C with continuous counting. I want to detect last position when sw off. for example want to read cut size. I have installed encoder on one feed roller and other blade roller have proxy sensor for end blade cut. I know feed length can be measure by encoder pluses x diameter of roller x Pi. if i control SW with proxy sensor in ob40 but i can not find quorate no. of pulse after every cut. I try to use proxy sensor as HW gate control but result is same. Any one please help me.
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
80
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,396
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,792
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,139
Does anyone know how to set the output window on-off values on the fly without having to inhibit the module? I could of sworn when I first started...
2,385
