S7 IEC timer preset from MP panel
jtpetersen
Jul 2005
Wisconsin
Hello all. This is my first post.
I want to enter a time (in seconds) from an MP and use it as a preset for an IEC timer. I can't get ProTool to accept my TIME tag in the Step 7, any ideas on that? Or, how do I convert a DINT variable to a TIME variable to use as the preset to my IEC Timer?
Any help is greatly appreciated...
Hello mr. Petersen :)
You have to create a tag in Protool that uses the DINT type.
In S7 you have to assign the same address the TIME type (silly, but it is just the way it is).
You may want to use the scaling options in Protool for the tag to scale it from milliseconds to something more userfriendly (seconds maybe).
Do the same to present the actual value on the operator panel next to the setpoint value.
Regards,
Pedersen !
I recently discovered that when downloading an online edit [S7-1500] that requires the initialization of the modified FB's iDB, an IEC timer whose...
36
11,923
Tried Googling and searching this forum for the answer to this, but no luck, so figured start a new post to see if anyone can help me...or confirm...
3,410
After a previous post I have been trying my best to set up a simple s7 IEC timers within a FB (Timings) and then use it from a FC (FC1). I have...
24
3,343
Hi all, :huh: How the IEC timer works? I tried to simulate the IEC timer SFB4 in FB but it seems its hard for me to analyse where I...
4,375
Hello! I intend to use the iec timer SFB4 for alarm blocks. In order not to use up one instance data block for each timer, my intention was to...
7,746
