S7 memory upgrade
Krish
Aug 2004
25
I need to increase memory capacity on a S7 416 which has integrated memory with a 512 memory card. The load memory is currently at 96%. Need more space for upgrades.
I want to upgrade the memory card to a 1 meg.
Are there any known problems with such an upgrade.
Hello Khrish;
There is no problem if you want to upgrade the load memory. Just power down the PLC, swap cards, power up and download the program to the new memory card.
The s7-416 has a basic work memory oy 2.8 MB anyway, so your 1 MB memory card will never exceed the work capacity of the CPU.
Hope this helps,
Daniel Chartier
I have a SLC5/05 with the standard 16k of memory, and I'm out of storage space. Are the 32k/64k memory chips just plug and play, or does it...
1,191
I had a 1747-L542 32k processor that was only showing "3 instruction words left" for Memory Left. We swapped this out with a 1747-L543 64k...
2,553
Hi, Does anyone know if you can still get memory for the S5? I think the CPU is a 135U. Thanks
3,886
We've been programming a 1756-L55/A 1756-M13/A ControlLogix Controller, and have run out of memory (1.5 MBytes) with only about half to a third of...
6,162
Hello! Just one small question: Is there any way to increase the memory of SLC 503 CPU? BR Lauri
3,838
