SLC5/05 memory upgrade
bigsteve
Aug 2020
Memphis area
30
I have a SLC5/05 with the standard 16k of memory, and I'm out of storage space. Are the 32k/64k memory chips just plug and play, or does it require a more complicated setup? Will I have to download the program again after I install a new memory chip or just it power back on and go?
Last night I was trying to revive an old derelict machine after a slumber of many years. I couldn't connect to it with 1747-UIC cable from...
2,130
hello, i have a slc5-03 that is failing to retain the program on power loss. i have installed a new battery and the jumper on the board is set to...
1,371
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,559
I am trying to connect to SLC5/03 using an FTDI usb to rs232 with female to female converter at 1 end... however I can not connect to it ... the...
1,273
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
639
