S7 SCL & Graph
CharlesM
Aug 2005
Arkansas
1,129
I have been working on some loops in step 7 which are requiring me to us STL. I asked my local Siemens tech support guy some questions and he said I should purchase SCL. So my question is should I buy the SCL software or should I upgrade my Step 7 Basis to Step 7 Pro? I am told that Pro will come with SCL, Graph and Simulator. Pro is about $500 more than SCL by itself. Is it worth it for Graph and Simulator? What is Graph used for?
I would recommend the simulator and always use it to try out code before running it in a real plc (or submitting code on this site!).
Graph is a programming tool that allows you define a process as a series of steps and transitions and is idealy suited to controlling a sequence.
Pro it is
Most of the time (90%) I have hardware to work with so Sim may not help much. Graph looks good. I do some sequence work that it could help out on. I guess I will order Pro on Monday. Thanks for the suggestions.
Hi, Is it possible to convert Graph program to STL or something like this which is modifiable by programmer.
5,053
Hi! I think the same subject was mentioned before in here.BUt it is difficult for me to design an elevator with SCL and s7 graph.I made it with...
3,321
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have an intermediate-advance knowledge of programming with TIA Porta in Ladder, would you recommend me to start learning SCL for it to...
564
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
320
