S7 TIME format and Citect
Apr 2003
25
Hello, I am working with the FB 41 (CONT_C, Continuous Control) for P+I control. I use Citect as SCADA. To address GAIN parameter I have not problem because it is in REAL Data type, but the I (INTEGRAL) parameter is in TIME format (example: T#20s). How to address this in Citect and how I pass this parameter to the I input of the FB 41.
Eduardo
Eduardo
Move your TIME format to/from REAL format and address that in Citect
Hi everone. I wonder if someone knows how citect HST fileformat is upbuilded? It would be very grejt. Its kind of a binary fileformat contains...
2,939
Good Morning List (at leats it is here). I want to change the default Alarm Display Format in Citect. Inthe documentation it states that this...
4,778
In a PV 5310, can you format a numeric object to create comma's in the thousands position? I see no way from the properties panel.
459
Hi all, if I remember correctly, there is some way in a ControlLogix (or CompactLogix) where you can sort of map tags into SLC addressing format...
1,166
I can't see any option to display the date in UK format, i.e. dd/mm/yyyy Is it available in TIA Portal v18?
21
1,804
