S7 values to Excel
Fonzie66
Apr 2008
Doetinchem
27
Dear SIEMENS experts,
At our company we are building a test machine. I want to transfer 4 values from the PLC to an excel file every 10 seconds.
Available hardware:
- S7315 2PN/DP
- IPC with WinCC flex runtime as SCADA connected to the PN port of the PLC
What is the best starting point to do this. I have read some thing in the helpfile from WinCC about the SOAP toolkit. Is this the best way?
Well that depends.
I remember once I had to record some variables with time stamps and I easily configured my wincc flexible project.
Try this and let's us know what you did.
Regards
Hello, When I copy the start values from a DB to an Excel sheet the format is wrong. I changed the format options in Excel but won't help. Can...
21
3,987
Is there any way to export live tag values to excel using rslinx classic lite?
3,647
Hi all, I have a UDT with two STRINGs and four REALs. I have to put a value in each of the 6 members...in a 300-element array. I have the values...
19
10,888
Hi Guys, Im back again after 1&1/2 year. But my question is... How can I read values in excel file especially from one column then compare it with...
1,940
Hey, I am able to read values from a test SLC 5/03 plc into a excel spread sheet by configuring a new DDE/OPC topic in RS Linx 3.60 but how do...
2,168
