Read, Compare & Write Values from Excel file
maiko
Feb 2012
Praha
17
Hi Guys,
Im back again after 1&1/2 year.
But my question is...
How can I read values in excel file especially from one column then compare it with value in plc and then write other values whitch are located in same row like compared value.
Thanks in advance.
Maiko
For free, check out archies advanced HMI. Search forum for it. I'm pretty sure there is an E/IP driver for CLX support. Also search forum for example of using it as your interface between Excel and CLX. After that, you should be able to do your comparisons using excels functions.
AdvancedHMI does have drivers for the CLX processors and can interface with Excel spreadsheets in several different ways. There is a topic on the AdvancedHMI forum that discusses using Excel Automation with AdvancedHMI. It is probably the most difficult method and does require a little bit of VB knowledge, but it allows viewing of live PLC data in Excel.
http://advancedhmi.com/forum/index.php?topic=679.msg3168#msg3168
My preferred method is to use a software tool called EPPlus. It doesn't let your view live data, but is much easier for reading/writing Excel data and it does not require Excel to be installed on the PC.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
161
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
127
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
261
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
103
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
151
